97 sportsman 500 is this knock normal? Driving me crazy. Help!
Runs fine it bogged in video a little but I have air box cover of. Checked cam,valves adjusted" sounds low can tell if clutch or motor .watching videos people say it's normal Polaris knock. Runs fine don't get worse with rpm increase. Please help. The clutch does have very little side to side play and the weights move side to side and I can push clutch in about an inch. I do hear belt slap cover
Does have new starter ,Bendix and both starter bushings no change. Was told oil pumps are loud. I did notice with plastic off it's loud coming through snorkel by gas tank and when putting hand over opening it quiets slot.like magnifies it. And help appreciated before I give up and get rid of it. It runs strong just worried about bearing,rod,piston. I see a lot of videos and slot sound this loud is this normal.lol
Drive clutch guide buttons worn down to where the spider is clacking against the clutch towers.Usually quietens as you give it throttle. If in doubt just pull the drive clutch and crank it up. There will be a little in and out play on the drive clutch.Another way to tell is to rock the clutch outer cover plate side to side. Any amount of slack is magnified when you crank it up.Items 3,5,13. Be sure to see if the guide button towers are heavily grooved where the buttons slide.
Ok removed the clutch. Started it and that loud banging is gone. The buttons have about 1/8 inch play and wore bad grooves. Has some side to side play. I think I'll just purchase a new clutch on eBay. Wish I could figure out how to attach video before and after? There is a little noise from the motor when it warmed up,but I would expect some little ticks and rattles from a used four stroke? They do seem a little noiseer than other engines. Thanks for the help. I have a manual but Polaris is new to me. I'm a Yamaha guy😜. I'll try to post second video to see if that seems normal for a Polaris engine.
https://youtu.be/aAJrQWcqbOY
Here is video without clutch on. Let me know if you think that sounds normal for Polaris. Sorry about quality had my hands full.
https://youtu.be/zB3OM7_-h4A Here is first video with clutch on feedback would be helpfull
