99 sportsman 500
Old 10-20-2010, 10:28 PM
Blackhills's Avatar
Default 99 sportsman 500
When I'm in awd and going forward I will stop and go into reverse pushing override button it wants to pull real bad like one hub is locked in and one isnt, anyone have this problem
Old 10-21-2010, 07:16 AM
Kerbbirds's Avatar
Change the oil in the hubs
Old 10-21-2010, 09:20 AM
EPIChad's Avatar
You need to clean the hub and bearings and put new oil in it. The Polaris oil is best.
Mine would do that because I had a bad hub seal. Sometimes when it would start to do it you would need to go forward and backwards a few times to make both sides work the same.
Old 10-21-2010, 09:31 AM
TLC's Avatar
TLC
TLC is offline
More than you care to know about Polaris AWD hub link. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
If your seal is gone it will leak at the inside of the wheel rim. just changing the fluid and taking nothing apart will fix that problem in most cases.
Old 10-22-2010, 08:31 AM
EPI Brandon's Avatar
Make sure when you disasemmbly the hubs you clean up the armature plate that gets magnatized thats usually the main thing that starts hanging up. its just the small thin black plate i usally use really fine sandpaper to get out any grooves it may have caused.
chingchangchong
08-07-2022 11:36 AM
Jmuddin284
06-28-2017 04:59 PM
slowgsxr97
09-08-2015 07:33 PM
Pahuntman
09-05-2015 11:07 AM
cdstang
08-31-2015 07:52 AM
Quick Reply: 99 sportsman 500
