Newbie: Polaris 500 ho stalls, no 4wd in reverse
Old 05-19-2008, 09:46 AM
Tburg Jeff's Avatar
Default Newbie: Polaris 500 ho stalls, no 4wd in reverse
thanks again for the advice.
this atv starts cold even without using the choke. I took it out last night and didn't have any problems. I read the manual inside and out but did not memorize it. I am going to go through the steps atvgooroo advised and let you know of my results.
thanks jeff
  #22
Old 05-19-2008, 08:57 PM
Tburg Jeff's Avatar
okay................
this is definately a throttle issue. I did as atv gooroo advised and adjusted the throttle...all went well but when i tie wrapped the wire back to the handlebar the throttle adjusted itself higher. So now I can adjust the idle throttle by gently tugging on the throttle cable, which sucks. Now when I am riding the throttle cable only has to move a little bit to screw the idle throttle up, which is probably my main problem. I gently move it by the ETC box and it changes idle.
Any ideas???
jeff
Reactant
03-30-2022 02:08 AM
Cole Hadden
08-24-2020 11:11 PM
maxjung
07-13-2015 05:11 PM
Scottma518
07-10-2015 12:42 AM
bikedad3
07-02-2015 02:15 AM
Quick Reply: Newbie: Polaris 500 ho stalls, no 4wd in reverse
