Counter balance oil problem...
I just bought a scrambler 400 that ran fine. I took it riding last weekend and noticed that it was harder to start afeter I had rode it a while. I got home and went to change the counter balance oil... nothing! I poured about 3.5 oz of 10w30 in it and when I started it back up it started smoking pretty bad, white smoke. I went back and drained the oil and noticed it was a redish color, almost like rusty. I changed the oil again and it was still smoking. I shut it off and left it alone. I not a mechanic and am new to two strokes. Any ideas? Bad seals or just needs to be changes or flushed a few times?
Item#4 is the 10mm drain plug,item #41 is the dip stick(located underneath the carb area) Takes 75ccs (little less than 3 ounces) of 30wt or 10w30 oil. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse You can either fill it at the dip stick hole or at the front of the engine. Plug #27.
