Sportsman 335 engine shuts off when the gear shift is put in reverse.
Old 11-15-2015, 10:45 AM
I don't have the 06 manual,just the 05 for the 700/800 and shows a violet /white wire coming from the speedo connector also,but it's for the fuel pump. This mod may or may not work on your model,but I'd suggest getting this cheap 5 buck manual with the wiring schematic that can guide you.2006 Polaris Sportsman 800 EFI Service Manual PDF Download
  #22
Old 12-28-2015, 07:32 PM
keizer's Avatar
Hi Old Polaris Tech
I am having another issue with my 1999 335 Polaris Sportsman. This time the AWD works intermittently when I have the button pushed in on the handlebars and the indicator light comes on. It does it forward and reverse. I have been stuck and the rear wheels will spin then after a while the AWD will kick in and work. It will work for a while then stop working. What can I check for a fix to this problem. Thank-you.
  #23
Old 12-29-2015, 03:49 AM
Look at your post in the expert section.. No need to post twice in both areas on the same problem..
ROWALKER
06-15-2015 05:38 PM
Dylan.11
Utility ATVs
06-04-2015 03:58 PM
winterwolf
ATC 3-Wheelers
06-03-2015 07:34 PM
Fullblast
05-26-2015 12:38 AM
swire
10-30-2000 03:25 AM
Quick Reply: Sportsman 335 engine shuts off when the gear shift is put in reverse.
