fuel guage stuck on full
Can't remember if this model had the wire arm with the float or the slider float in the pump. Either way sounds like the float may be may be stuck against the side of the tank(if it's the wire arm model) or a wiring problem if the float's in the pump assy. If this used one for sale is for the correct year model,then I'd bet the float arm needs to be bent out a tad and it should go back to working ok.#567 2007 Polaris Sportsman 500 4x4 fuel pump assembly
