3lug wheel spacers?
Old 01-21-2017, 07:56 PM
TaoTao110D's Avatar
Default 3lug wheel spacers?
Hello, my daughter has a taotao 110 atv and we love it for its price.
Done a few simple things to make it nicer. Only thing I want to do but can't seem to find is 3 lug wheel spacers on the rear to make it a little more stable.
I've seen one company that makes 3 lug spacers for china atvs but they are 3 inches thick a piece which is 6 inches total. Too much for me.
Anyone know where to get 3 lug wheel spacer that are like 1",1.5" or 2" max for a taotao 110 atv?
Does this share its 3 lug wheel bolt pattern with any other small atvs? Might make searching for spacers or wheels a luttle easier.
Old 01-23-2017, 02:55 PM
SlowSL's Avatar
I see on Ebay they have spacers that are studs rather plates, so they can be used with any bolt pattern. They have one end male threaded, to fit through your hub, and the other end female, so your bolts can thread in, extending your rims. If you need something special made, give me a shout, I work at a fab shop.
Old 01-23-2017, 06:33 PM
Kymco 450i's Avatar
Depending on what material you make them from it should be a fairly simple job for a machine shop to tackle. For the small youth machine I would think some easy to make aluminum spacers should do the trick.
Old 02-01-2017, 05:37 PM
TaoTao110D's Avatar
yeah ive seen those lug extenders but worry about the reliability compared to "regular" wheel spacers...last thing i want is a wheel flying off my daughters quad . any of yall have experience with those stud extender wheel spacers? what thread pitch will i need?
Old 02-02-2017, 09:36 AM
Zrock's Avatar
I would not trust those stud extensions. That is to mush force on those studs and now the rim will not be sitting against the hub causing more stress on the studs.
Old 02-02-2017, 11:23 AM
DirtDevil101's Avatar
Dura Blue makes 3x120 2.5" urethane/titanium spacers as well as others...not cheap but better than stud extenders...
Old 04-12-2018, 11:34 AM
koolhandlinc's Avatar
Default so basically no one nows where other than 3 inch
so basically no one nows where other than 3 inch. I would be willing to get the 3 inch if they were 40 or 50 bucks. That little Tao Tao is a rocket fast and then unstable in turns. First outing my son turned over 6 times. I am going to change the front sprocket 1 smaller to slow it a little.
Old 05-08-2018, 01:49 PM
stanghater's Avatar
these are pricey but the best and only ones I could find for the 3 lug
Wheel Spacers - Mini and Kazuma 50 ATVs - ATV Rims & ATV Wheels at Raceway ATV
Old 06-21-2018, 02:13 AM
Whystock's Avatar
Default Buy 2" wheel spacers here
http://www.whygostock.com/wheel-spacers-for-6-wheels-boulder-b1-b110-2/
