frame restore
Old 01-23-2017, 06:32 PM
DoctorQuad's Avatar
Default frame restore
whats a good tough paint that i can use to repaint my frame?
lots of rust so im gonna strip the bike and sand blast
Old 01-23-2017, 06:36 PM
Kymco 450i's Avatar
Sand blast "all" the rust off or you will have problems. Then a primer coat and then use an epoxy base paint or if you can swing it get it powder coated. Epoxy paint is what is used on appliances and it is hard to chip off if properly prepped and fully cured.
Old 01-23-2017, 06:41 PM
hydrex's Avatar
Try some rust killing primer, then just rattle can with Krylon or any rattle can paint. Then once the top coat has cured, spray with (Truck Bed Liner). I've used Rust-oleum Truck Bed Coating. Should be easy to find at NAPA auto parts, Walmart, etc. It's not as good as Line-X , but for do it yourself, it's pretty good. You can probably spray it over the rust converter. Can't say if it's as tough as epoxy paint, but it's easy to touch up. I was actually thinking of taking the racks and bumpers of my Arctic Cats and taking to the Line-X guys. Stuff has held up great in my Ram's bed for12 years.
Old 01-23-2017, 06:55 PM
DoctorQuad's Avatar
I have a small pin(width) needle hole about a half inch long, can this be welded or am I screwed?
Old 01-24-2017, 04:00 AM
Frames can be welded, no problem, but you often find that the rusty area is a lot bigger than thought as the metal round the hole is thinner than a razor blade. You seem to have lots of problems, paintwork, oil cooler, changing engine, rusty frame, could be time to scrap it and get a better Quad.
Old 01-24-2017, 10:45 AM
DoctorQuad's Avatar
I just bought it for cheap lol. The engine is strong, I bought it to for a project to keep me busy anyway.
Just my luck I put up a ad for a new frame and someone emailed me within 5 mins with a solid frame 60$
