2000 suzuki quadrunner 160 timing
hey welcome to the forum! if its anything like an lt230 (which im 99% sure it is), the two hash marks on the cam will be level with the head and the indexing pin will be at around 11 o clock when the crank is at the position where the line on the flywheel lines up with the pointer in the case...
good luck!
good luck!
