'03 Eiger 400 no high beams, speedo light, tail light ?
Trying to diagnose why I don't have any lights in these areas. Fuses are OK; don't see any obvious problems. Wiring diagram in tech guide leads me to believe a common problem, but so far no luck. Any suggestions from more experienced folks out here?
All feedback appreciated!! Hunting season is coming!!
Thanks!
Tom
Thanks!
Tom
have you checked the wires behind the speedo? on my vinson i had a similar issue no pod light and no digital display backlight. I discovered one of the wires was chafed and broken. Turning the bars had caused the chafing. I joined the wires and put some plastic protection (split wire loom) over the wires to prevent this in the future.
Mystery SOLVED!!!!
Well, I found the problem. Goofy headlight switch is bad!! Play with it a little and the high beams, speedo light, and tail light work! Waiting now on new switch assy and replacement tail light assy (PO had broken it).
Now for a little adjustment on the rear brakes (so the foot pedal works) and I'm good to go! Also buying a winch for the front.
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
