break in advice
Old 09-17-2011, 12:24 PM
lt230inwiscasset's Avatar
Default break in advice
hey guys. I just got done rebuilding my 87 lt 230 engine. mostly stock accept for crank parts and 66.5 mm. wiseco piston. I was hoping someone could give me some advice on what I should do before I crank it over and how to gently break it in
Old 09-20-2011, 12:45 PM
diamonbird's Avatar
You want to keep it under a load and low rpm's for at least the first 15 mins.
Go hill climbing but not hills that require high rpm's to pull the hill.
Do not start it just to hear it run, the first 15 mins. of run is what seats the rings!
Old 10-04-2011, 12:25 PM
Default appreciate it.
hey thanx alot diamonbird. I took your advice and it went well. It's awesome to ride without seeing a smokescreen behind me. I've never rebuilt an atv engine before but having the crank rebuilt at a machine shop and re-ringing it made the rebuild worthwhile. The LT is running awesome after it got done smoking at first as to be expected while the rings were seating. thanx again.
Old 10-04-2011, 03:31 PM
sporty982000's Avatar
What we use to do for new engines at the shop, was add a little 2 cycle oil in the gas for the 1st tank on the new engine also. this helps with a little extra coating.
We would add like a 2 liter plastic cap top, full of the 2 cycle oil into the tank.
ultangler
09-05-2021 08:06 PM
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
kodiacrunner
10-04-2015 11:52 AM
wrencher82
09-28-2015 10:02 PM
Quick Reply: break in advice
