Rear Carrier Bearings Replacement
My rear axle makes a creaking noise when rolled in neutral. I adjusted chain and checked brakes, and they aren't the culprit. Checked with a local motorcycle shop here and they said it'd be "a few hundred dollars with parts and labor" as long as its a routine job. Said it could be more if things are siezed or any other issues arise.
I then called the Yamaha/Suzuki dealer and they said $250 plus parts and didn't mention maybe more if any issues. My axle isn't wobbling or anything, but it sounds like it is time to change them. Any thoughts?
Derek
Derek
