LT80 starting problems
Old 01-30-2017, 04:33 AM
Aitken74's Avatar
Default LT80 starting problems
I have an 1990-ish LT80 which turns over slowly and won't start unless it's jumped from my car. Once jumped it runs perfectly.
After reading posts here I tried taking the spark plug out and it turns over normally, but if you put it back in it turns over slowly again.
Anyone any idea where the problem lies? Is it starter issues?
Thanks in advance for any help, plenty of experience with cars and mechanics, but new to quads.
Old 01-30-2017, 07:56 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I feel the starter may be bad providing that your battery is fully charged. It's sorta weird that the jump helps.
A stock Suzuki starter can roll over a jet engine.
Old 01-30-2017, 11:25 AM
DirtDevil101's Avatar
It's probably on it's way out and drawing too many amps for the stock battery...a larger battery would most likely have more CCA (cold cranking amps)...or the stock battery is on it's way out...taking a charge is no the same as an amp test...
Old 01-30-2017, 02:05 PM
Aitken74's Avatar
Hi all, thanks for the quick replys yeah I had the starter in my mind as the trouble and al get a new battery, can you recommend the best battery for it?
