gaskets and gasket sealers
Old 01-10-2008, 04:39 PM
Reno 5150's Avatar
Default gaskets and gasket sealers
When you are replacing the gaskets on any part of the motor, do you have to use yamabond or something similar, or is the just gasket by itself ok? If so, how much and on what side of the gasket? For example, the cylinder head and valve cover gasket - use both or just the Yamabond? What's best? thanks
this is the 1st time tearing apart my motor
Old 01-10-2008, 05:15 PM
Raptor450's Avatar
What kind of bike? I never use gasket sealer on anything. I've seen some people use a light coat of sealer on top of the gaskets. In my opinion if the gasket by itself leaks then your gasket didn't seat properly or needs to be replaced. Definately don't use the sealer on your metal headgasket.
wrencher82
09-30-2015 04:27 AM
wrencher82
09-28-2015 10:02 PM
tysonbully
09-28-2015 02:30 AM
wrencher82
09-24-2015 03:39 PM
Quick Reply: gaskets and gasket sealers
