YFZ 450 cam mod problem
Welcome to forums nkdurrett.
So ya, I'd say take it back to the dealer and make them fix it but, you probably just voided your warranty huh?
Sounds like it's a timing issue. From what I here it's easy to miss align to cam teeth and chain. Were you sure you got the cam moved 1 notch only?
also, this happened to my buddy that when they took the chain off entirely, the rotated the crank 180 degrees, according to them, it backfired and wouldn't start. If you did do that, and took the chain all the way off, then rotated the crank, this might be your problem as well...in doing the cam mod the chain should not have come all the way off though, so you should be good...none the less, try what i said up there ^...good luck
<div class="FTQUOTE"><begin quote>Originally posted by: nkdurrett
yeah i had to put it back to stock and it ran fine. and when we did the mod we didnt take the chain all the way off</end quote></div>
hmm...well i dunno =)...good luck? at least it's still running at all [img]i/expressions/face-icon-small-wink.gif[/img]
