yamaha big bear 350 fluid question...
Old 09-02-2011, 08:53 AM
homerj's Avatar
Default yamaha big bear 350 fluid question...
i recently bought a used yamaha big bear 350. trying to go through all the fluids to make sure it's good to go but i have come across something that i can't figure out. on the left side near the pull cord there is a plug with a flat head slot for removal. unscrewing it, it's obvious some sort of fluid is supposed to be in there but i can't find any mention of it in the manual though i may have overlooked it. there's also no dipstick so i wouldn't know how much to add. any help would be greatly appreciated. checked the engine oil & gear oil and they both look good. needs a little brake fluid but that's in the manual.
Old 09-03-2011, 11:19 AM
homerj's Avatar
Anybody? I can take a picture if that would help.
Old 09-03-2011, 09:35 PM
vangasman's Avatar
I believe that is the timing plug. Should see some kind of mark somewhere in there.
Old 09-04-2011, 04:20 AM
homerj's Avatar
thanks man. looking through the manual again i believe you're right. it just looked like a fluid port & i wanted to make sure before i went off somewhere on it.
Old 09-04-2011, 05:41 PM
95wolv's Avatar
Vang is right on, there are actually 2 of those, a big one on the side of the case, thats where you put the socket to turn the crank, and the smaller one above it, where you look for the timing marks.
Old 09-05-2011, 01:25 AM
homerj's Avatar
thanks guys. i was just concerned that there was supposed to be gear oil or something like that in there & i didn't want to do any damage running it low.
Old 09-10-2011, 09:49 AM
450kodiak's Avatar
x2
Ean
12-19-2022 08:48 AM
robert301972robert
08-30-2015 11:34 AM
NatePerz
07-27-2015 03:27 AM
Peter_
07-18-2015 07:06 AM
rcappie4
07-10-2015 04:54 PM
Quick Reply: yamaha big bear 350 fluid question...
