2005 Kodiak 450 questions
Hey my 4-wheeler is a 2005 Yamaha Kodiak 450. I bought it for $800 after it sat for a year and it has 920 milles with 360 hours. Came with a winch, 27" Mud Bug tires, and a snorkel. I just rebuilt the carbuerator and it runs great, but too great. I mean it has power. I was wondering if this could be cause it is bored over, and if it is, is that bad for it? These are some fat mud tires and and i can punch the gas at 20mph on a packed dirt road and kick up dirt, and when I can climb hills it shoots quite a rooster, on accident! I just would like to know if this was a deal and how to tell if it's been modified. the jets are brand new, but stock, and this thing will haul a$$. Any help is greatly appreciated!
P.S. I know this is off topic but when I bought it the airbox was FULL of dog food from rats stealing it from the guard dog! hahaha.
It's possible that an after market clutch kit was added to it. I have 27" ITP 589's on my 06 Kodiak 450 and though after purcahsing the wheels and tire package brand new and putting them on I noticed how much better my atv is with traction and not having to use 4wd where I had to previously with the crap stock wheels and tires. I did however notice that after putting this huge tires on I felt that I lost low end torque. These tires are real aggressive and basically will only fling mud when going through a real muddy area if I get on the throttle enough. They wont spin out like the stock tires due to the very aggressive traction on the tires. I had a moosel clutch kit installed and all is good now. When I go through a mud bog like out in PA where there is alot of coal dust mixed with the mud in many areas, it rode through it without any power loss issues. I did loose top end and how fast I can travel after adding these tires on, I think my best top speed is 46-48 mph with them on. I'm also over 200 lbs so my weight also plays a role on top of that.
A little heads up, beaware of mud collecting on the drive shaft where the drive shaft meets the engine. There is a rubber seal there, and if you don't clean that area off really well with a hose, the dried up mud can screw up the seal and cause an oil leak. It was a $400 fix at the dealer for me. Now everytime after I ride no matter what, i hose the atv down and get all the mud off (especially in that are). I also added some red grease and spray this chain lube that dries to a waxy finish, to give it some protection from the mud. Yamaha recently revised this issue with 12 models and added a one peice drive shaft without a yolk like our machines have. I also like how they went to a wet brake instead of open disc, cause the pads wear out way to fast when you ride through mud and water.
Thanks man, greatly appreciated. I don't think I have a clutch kit, but if I wanted one, how much would it cost and how much trouble would it be? I'm 15 and weigh 160lbs or so, so I don't think I make a difference. And also, It has one snorkel that goes to the transmission, and then a bunch of tubes strapped beside, I know it doesn't have a airbox snorkel, but you got any idea what these could be for? Plus my radiator fan is out (I think). The red overheat light comes on when I go through thick mud or climb hills, but when I'm driving around it cools off. So I knew it was the fan. We ran its power cables straight to the battery and nothing haappened, but the manual says theres a circuit breaker switch. Could that be the reason? Or even the thermostat? Once again, any help is greatly appreciated.
I have since put another 150 miles on it no leaks! Also when I get a chance - I am going to take the Yoke (only a $35 part) to a machine shop and see if they can turn it down and put a piece of stainless steel sleeving on it.. because we all know that stainless steel is much harder than whimpy cast metal
RedRancher
10-15-2020 01:45 PM
