raptor 350 clutch engagement
whats up guys... I had a question about the clutch engagement on the raptor 350. I recently put a clutch in my girlfriends quad and where the clutch starts to grab is almost fully released compared to my 700. My sister has an 08 and this is the same. The clutch seems to grab fine, theres no problems, I just dont know if its on its way out again due to how late its grabbing. Any insight is greatly appreciated. thanks guys
chad
chad
It should be fine, just make sure your clutch cable is not adjusted too tight, needs a little play in it. You could probably adjust the cable at both ends if you don't like the way it works now. Start by giving some slack at the bottom adjuster and then re-adjust up top at the handlebars. I always liked mine adjusted how you describe, you don't have to pull it in very far to change gears and when stopping!
