Help With old timberwolf
I just bought this Yamaha timber-wolf 250 for $600. Isn't in to bad of shape, the problem is the only ways i can get it to start is kicking it into gear while being pushed or jumping the starter with cables. The push button does nothing. Ive tried replacing the battery, the silinoid. still nothing. Any ideas??
-not a pull start ethier
- Not sure on the year. guy said its a 95 or 98.
Is power getting to the push to start button from the key?
Does it then get to the small wire for the starter solinoid from the push to start button?
If you hook power to solinoid small wire it should clickthe solinoid shut (if it is working) and this should cause your starter to crank over the engine, assuming suficient battery power is getting to the soliniod. The starter must be fine if you can jump it with battery cables.
Ken
Ken
