HELP PLEASE....yamaha moto4 80cc wont start
my atv stopped running outta nowhere and cant seem to figure out why... it sat for 3 years and just recently decided to fix it. i got it running by cleaning the carb and rode it for a couple hours and parked it over night and when i tried to start it the next day it just kept turning over but wouldnt fire.. so i checked the spark and it has plenty of spark. so then i noticed the carb was spitting gas out the air intake and and the overflow drain.. so i bought a rebuild kit for the carb and did that and it stopped comming out the overflow.. ive pulled it down the road behind my truck and got it to start up finally but the only way to keep it running was to make the rpms tach out to the max... does anyone know what my problem could be?
Could be that your carb float is off. Maybe overcompensated for the overflow and now running lean??? How many turns out is your fuel screw? 2 is a good start. If you're in cold climate, turn out another 1/2 and see how it goes.
Why did you have to bump start it though? I would work on ignition system first.
ive got compression... i put some valve lube in the cylinder by the spark plug hole to see if one of the valves were stuck open and i got a little more compression back.. but i dont see how a valve would get stuck over night... when i do get it running it runs good for a min by pulling it then starts to bog down after i shift from 2nd to 3rd or 2nd to 1st.
i pulled started it cause i was thinking the starter may be to weak to start it but the button. the ignition system is good and all electrical is fine, i have the screw adjusted like at 2 turns. im in florida so dont get to cold.. it was running like a champ when i parked it. then went to go mud riding in the morning and it just wouldnt start
First check valve clearances, if it is the Yam engine I am thinking of, the valve clearances close up and you can only start by towing. Secondly, that carb overflowing was dirt from the tank getting stuck in the float needle. Some more may have got into the carb so clean it out again. If you don’t fit an in line filter you may have to clean the carb out several times before all the bits from the lay up have gone from the tank.
No, the valve adjusters are on the rockers under the two screw in caps on the head. Apart from the rocker covers being screw in, the adjustment is similar to what is shown on the other Yamaha posing from yesterday see Yamaha question, the interesting bit is 8min in on the first video. I don’t know the clearance but try 0.003” with the piston at top dead centre on the compression stroke, the engine should run at that.
