1988 yamaha 350 big bear need parts
I have a 1988 yamaha 350 Big Bear 4x4 its a pretty reliable machine but a couple months ago one wheel stopped spinning i found out later it was the part that hold the wheel it spins with the axle but the teeth that make the wheel spin were chewed up and i have absolutly no idea where i can get the part other than kijiji or ebay please help woul a YAMAHA Dealer have them?
Assuming you are referring to the rear hub and axle, any Yamaha dealer will have the parts, but if the splines on the axle shaft are shot and you need a new axle you are in for a big bill. The rear hubs are not very expensive.
Honda 300s were prone to this and, instead of new parts, we used to run a bead of weld round the joint where hub and axle meet, not on the nut side. Aftermarket suppliers started making shafts and hubs cheap for the Honda so we now fit these instead. They don't make them for Yams though as Yamaha kept changing the rear axle so there aren't enough of each type to make pattern parts worthwhile.
The hubs are not much and easy to change. Part number 6 or 1 depending on which side. $68.89 from this place. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse they call it a COLLAR,WHEEL. Part# 2HR-25383-01-00
toonces
10-16-2019 12:11 PM
