Only runs with choke, idling high
Old 12-20-2015, 02:33 PM
97exc's Avatar
Default Only runs with choke, idling high
2003 Bear Tracker. Cleaned the carb and jets. Pilot was clogged but I got it clear with a wire. ATV only starts with choke, once running it idles really high (when in gear it will drive without giving any throttle too). Will stay running with about half choke but dies as choke is pushed all the way in. I should also note that the choke itself feels like it's binding/sticking- it does not move smoothly in and out, there's a good bit of resistance. How would I go about cleaning that so it's smoother? Not sure what else to check or adjust to get this running properly..
Old 12-20-2015, 04:59 PM
Sounds like jets or orifices still stopped up. See if this video helps.
The following users liked this post:
ScottyRotten (09-05-2020)
Old 09-05-2020, 02:22 PM
ScottyRotten's Avatar
Sounds like jets or orifices still stopped up. See if this video helps.Cleaning the Carburetor on a Yamaha Big Bear 350! - YouTube
Thank you for this video , im rebuilding my mikuni for my 01 beartracker and i have a feeling this will help me tremendously.
socal dirt
04-04-2020 01:04 PM
MJS69
12-16-2014 08:59 AM
camaro1969
03-22-2014 04:44 PM
doorman95
03-25-2004 09:29 AM
Quick Reply: Only runs with choke, idling high
