2005 Big Bear Professional, your opinions please.
Old 04-18-2016, 04:29 AM
BBPRO's Avatar
Default 2005 Big Bear Professional, your opinions please.
Hi all, new here.
Not long ago I aquired a Canadian edition big bear 400 pro. It is a 5 speed with high low and reverse. The machine has very low miles.
Just curious what you folk think of this ATV?
Thanks
Old 04-18-2016, 09:44 AM
Fasteratv's Avatar
Originally Posted by BBPRO
Hi all, new here.
Thanks
If taken care of, very good, reliable machines. Enjoy!
Old 04-18-2016, 10:55 AM
BBPRO's Avatar
Thanks, that's very reassuring.
I'm new to atv s.
I changed the diff fluids and engine oil/filter. Had the carburetor rebuilt by a local small engine shop.
The BB iss now running like a champ.
Has Kenda Bearclaw tires.
Was in the snow yesterday and noticed my rear diff locked up. Can you tell me what type of locking diff does the BB have?
thanks
Old 04-18-2016, 01:44 PM
Fasteratv's Avatar
I'm new to atv s.
thanks
As far as I know, the rear diff is a solid straight axle....and both rear wheels always pull.....always locked up so to speak.
Old 04-18-2016, 03:12 PM
BBPRO's Avatar
Thanks
Yes, it's a solid axle. Good to hear it has a permanently locked rear diff, have not noticed any dragging of tires around tite corners.
Old 04-18-2016, 04:18 PM
BBPRO's Avatar
The only problem I have had is the rear diff vent oozing diff oil, not sure why, because the vent hose is located high up in front of the engine.
Checked diff fluid level and saw little to no change in the oil level.
Why should this be??
Old 04-18-2016, 05:10 PM
Fasteratv's Avatar
Overfilled, heat, pressure. I recommend draining, and refilling with fresh lube...then keep an eye on it.
Old 04-18-2016, 05:41 PM
BBPRO's Avatar
Replaced the diff fluid, will keep an eye on it. I suspect the problem will sought itself out.
scottaruth
05-01-2016 01:00 AM
manxman
04-13-2016 08:25 PM
Deerhunter96
04-10-2016 01:32 PM
danger2nature
2) Chassis problems..
03-22-2016 09:43 AM
Quick Reply: 2005 Big Bear Professional, your opinions please.
