kazuma 50cc won't stay running
Old Feb 5, 2010 | 08:02 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Originally Posted by efajeep
How do you find top dead center, what kind of markings am I looking for
Welcome to the forum efajeep!
Your looking for a F and a T with lines next to them on the flywheel. Under the cover on the left side of the engine(chain side). Those want to align with either a line or possibly 2 dost on the cam sprocket... A 4 stroke engine has 2 TDC's.. you want the one after the exhaust valves close. Remove the spark plug, Rotate the engine by hand turning the flywheel counter clock wise...when you see the exhaust valves close look for the T on the flywheel...its line will line up with a pointer in the case... This is the TDC to check valve clearance..
Old Mar 6, 2010 | 08:25 PM
wildwest383's Avatar
I have tried checking the valves it still wont start. It has good air and fuel flow, has good spark, got compression. what do I do?
Old Mar 8, 2010 | 07:57 PM
wade12019's Avatar
When u find out what's wrong let me know. I'm having
the same problem.
Old Mar 13, 2010 | 07:28 AM
Faf's Avatar
Faf
Did you scrap the chinese spark plug. That worked for me. The chinese plugs look the part, but the NGK is the part.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
jayking232003
Jun 9, 2015 02:54 PM
dcoleman
Oct 5, 1999 01:34 AM
