Kazuma Falcon 250 stock carb
Old Oct 23, 2007 | 04:30 PM
hedghog's Avatar
Default Kazuma Falcon 250 stock carb
I just modified my Falcon 250 with the following:
"Opened" up stock exhaust
Put in 15,5g variator rolls
Put on an open air filter, and skipped the stock air box
I havnīt opened up the carb yet and the question is what type of main jet is in the carb? And what size is it stock?
Is it "standard" kehein main jet or is there different thred-sizes??
Old Oct 24, 2007 | 03:40 PM
billl2099's Avatar
stock main jet is a xxx, pilot jet is a xxx, yes they take the stanard keihin round main jet for the cv carburators. the pilot jet is a series xxx , my cn250 ran the best with a xxx main and a xx pilot with a k&n airfilter and a fnf exhaust, most any m/c shops will have these jets or you can order them on line, heres one link xxxxxx.com
Old Oct 25, 2007 | 04:47 PM
hedghog's Avatar
I took apart the carb and main jet was 110 in mine. I changed to 125, and WOW what a difference. It really takes away great now!
I left the pilot as it was.
Old Oct 25, 2007 | 06:38 PM
billl2099's Avatar
if it's hard starting or you need to leave the choke on until it warms up then the pilot jet needs to be larger, if it's properly jetted then you should beable to start it and drive off just like your automobile
Old Oct 26, 2007 | 06:29 AM
hedghog's Avatar
Its about 0 degrees celsius cold here in Sweden and itīs starting straight away. I can drive it right of no hesitation...
Though what do You mean by leaving the choke on??? My has "auto-choke"... I canīt lever the choke manually?!?!?
Cole Hadden
Jun 15, 2025 09:05 AM
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
GregM
Mar 6, 2018 06:53 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
