Yamoto 250cc, question regarding main clutch assy.
Old Sep 29, 2009 | 06:26 AM
fjellfeit's Avatar
Default Yamoto 250cc, question regarding main clutch assy.
Hi!
I have been overhauling my Yamoto 250's gearbox, due to it slipping/crunching the gears when the load gets high. Problem was with the directional gear, as the forward bearing wandered around about 2mm. shimmed that up good, and its nice and tight now.
I also disasembled the main and secondary clutch assembly to check for wear, but they seemed alright, so I figured i would clean them up and put them right back in. Here is where I encountered my problem though, as i didn't note which way the lock-up bearing on the main clutch should go. Should it lock clockwise or counterclockwise? I'm thinking clockwise, so it locks the same way as the vario clutch.. Any hints?
Could also use some pointers on how to adjust the gears!
Thanks in advance!
Yours
Fjellfeit
Old Sep 29, 2009 | 07:01 AM
fjellfeit's Avatar
Resolved this myself, the bearing i was talking about is of course the engine break, and needs to sit so that it locks the opposite direction from the vario clutch!
Could still use some pointers on adjusting the gears on this "badboy"
Old Sep 30, 2009 | 07:37 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum fjellfeit !
Wish i could help you but Ive never had a Chinese 250 apart...I am looking forward to all I can learn from you and your tear down experience...
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
