chinese 150 quad
Old Nov 20, 2009 | 12:00 PM
owl1108's Avatar
Default chinese 150 quad
It have a ZD 150 and i cleaned the carb but still it wont start. It doesnt appear that I have fuel going thru the carb. What did i miss.
Old Nov 20, 2009 | 05:06 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum owl1108!
If your sure fuel is coming out of the tank and going into the carb...can be checked by pulling the fuel line and turning on the fuel...if it flows fuel thats good...Next is to see if its making it into the bowl...Most bowls have a drain bolt on the bottom...if fuel comes out of that then one or both of the jets are plugged...main jet is in the middle of the carb and pilot jet is behind it. Both should be removed to clean them and you need to make sure you can see light thru both of them...
Frisky2050
Apr 9, 2020 11:19 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
