For the electrically savy.......
Old Aug 25, 2010 | 11:45 PM
GH250's Avatar
[IMG]file:///C:/Users/Home/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Home/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/Home/AppData/Local/Temp/moz-screenshot-2.png[/IMG]
I thought the Coil input was coming from the CDI- so with the CDI off, I measured the black/white to green. Sorry if this is wrong.
I will go look the bike over closer and see what I can find. The measurement was truly .005 I was surprised it was reading out that far as well, but it was. It is a INNOVA 3320
Old Aug 26, 2010 | 12:06 AM
GH250's Avatar
Lynn,
The ignition output wire resistance (through the coil to ground) that was measuring 00.6-00.7 Ohm with the key on but not cranking, I obtained this at the same location (black/white to green). Again, sorry if this is the wrong location. Looking at the diagram- I thought this was the ignition output and coil input.
Also, I may be able to borrow an oscilloscope from a friend. He lives a few hours away- so it may take a bit to get it.
Thanks
Old Aug 26, 2010 | 12:29 AM
LynnEdwards's Avatar
Electrical Expert
Looking at the diagram it is indeed a black/white wire driving the coil. My bad...
Normally Black/white is a kill switch wire, but on your quad wiring wiring diagram it clearly is not. Your are measuring the right place.
Measuring zero volts at the coil input suggest that the CDI is not getting triggered. This is a very strange problem.
If you do manage to get an oscilloscope I do have waveforms for the CDI inputs and outputs that I can post.
Old Sep 1, 2010 | 05:42 AM
paul8mm's Avatar
Hey Lynn, following this post you stated you could post waveforms for cdi's , please post them or pm to me
thanks
Old Sep 2, 2010 | 01:06 AM
  #15
Electrical Expert
thanks
Yes, let me do that tomorrow (It's past 11PM and I haven't had dinner yet). I'll post them under a new thread with a more relavent title in this forum section.
Remind if if I forget! Life has been very busy for me of late...
Old Sep 3, 2010 | 12:27 AM
  #16
Electrical Expert
Photobucket is having problems tonight. I'll try to post later
Old Sep 19, 2010 | 11:53 PM
  #17
GH250's Avatar
Lynn, You definately were right from the begining. It was going to be a while before I could get the oscilloscope. Since everything pointed toward the stator, I just purchased a new one and it is sparking like it should. I probably would have tried this earlier, but I thought it would be a lot harder to actually change out.
Thanks!
Old Sep 20, 2010 | 10:24 PM
  #18
Electrical Expert
Thanks!
I'm glad it is working for you!
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
