Rear sprocket
Old Feb 10, 2010 | 07:04 PM
customroddr24's Avatar
Default Rear sprocket
Has anyone replaced the rear sprocket on a 250 VBike....? It looked like it would be easy enough to do but I can't figure out how to get sprocket off to put new one on. Any help or suggestions will help.
Old Feb 11, 2010 | 01:06 PM
Well I guess you can say I answered my own question. I figured it out on my own.
Here is a quick run down, remove rearend from ATV. remove right side tire from axle, remove jam nut then remove nut. pull axle out of housing, slid sprocket off axle then remove bolts from sprocket. put back together in reverse order.
Old Feb 11, 2010 | 02:39 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Glad to hear you got it figured out... Did you change the sprocket because it wore out? Or did you want a different sized 1?
Old May 16, 2011 | 07:45 AM
keithert's Avatar
Was it necessary to remove the rear end from the ATV? My son sheared off the bolts that hold the sprocket on. I hope to be able to use an easy out but I'm afraid I'll have to pull the sprocket. I think they sheared because he shifted into second at full throttle.
mywifesquad
8
Sep 21, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
