Tao Tao 110cc new atv questions
Old Feb 24, 2010 | 08:07 AM
  #31
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Originally Posted by nimadd
It's very common on 2 stroke outboard motors.
I gotta look at a outboard motor closer. Does it have low speed and high speed tuning screws? My lawn trimmer has a high a low speed screw.. Oh yah and on 2 strokes its a air screw...(for idle/low speed tuning).
Old Feb 24, 2010 | 08:08 AM
  #32
KTM Patrol
Former Chinese POW!
Originally Posted by OneTenCC
All I can figure is it's a cheap way to keep them "emissions compliant". These models also have the tiny catalytic converter and air injection on the exhaust. Mine has a rounded plug in the hole where the fuel screw was on the carb.
Joel
Your more than likely right...its a attempt to please the emissions folks..I want to buy a carb and remove the plug...I wonder if there is s screw under it or a preset needle type valve?
Old Feb 24, 2010 | 12:08 PM
  #33
OneTenCC's Avatar
Gotta be something under that plug/cap. Mine runs so good I just don't have the need to touch it. Worst case scenario, the replacement carb in the pic I posted above is $30. That one shows the mixture screw. Who knows if that's what you'd get though.
Joel
Old Feb 24, 2010 | 12:55 PM
  #34
nimadd's Avatar
In the outboard world single carb motors have mixture screws, multi carb motors have fixed orifices.
Attached Thumbnails Tao Tao 110cc new atv questions-55-carb.jpg   Tao Tao 110cc new atv questions-88-carb.jpg
Old Feb 24, 2010 | 12:56 PM
  #35
KTM Patrol
Former Chinese POW!
Joel
That what Im thinking.. Id try and remove the plug if needed... If yours is going good I would tn touch it either..What elivation do you run your quads at 110CC?
Thats part of the adventure with Chinese quads...Heck Ive been in China trying to get the right parts in the container...amazing how many clutches they make for the 90/110/125cc engines..
Old Feb 24, 2010 | 01:36 PM
  #36
KTM Patrol
Former Chinese POW!
Thanks nimadd! That clears it up a bit for me...I had just wandered down to a guy who fixes lawnmowers, motorcycles, atv's etc(near my shop)...He had a single cyl out board and it had 2 mixture screws..
Old Feb 24, 2010 | 02:45 PM
  #37
OneTenCC's Avatar
I'm at about 1100ft above sea level.
In regards to the mixture deal with outboards, snowmobiles and the likes, yes those babies can sure be sensitive. I've seen the aftermath of a multi cylinder snowmobile or 2 that leaned out too far at WOT. Meltdown!
Joel
Old Feb 24, 2010 | 03:39 PM
  #38
KTM Patrol
Former Chinese POW!
Joel
I was thinking you might be at 3k or so...(only because yours runs so well)
2 strokes are much more sensitive then 4 strokes are. Easy to melt a 2 stroke..4 strokes are much more forgiving..gotta be because about 95% of them are lean from the factory.. And Im not just talking Chinese stuff.. All of my Honda thumpers run much better and warm up faster with larger jets... Most 2 strokes are jetted rich from the factory to keep tham alive longer..
Old Feb 24, 2010 | 07:31 PM
  #39
jsills78's Avatar
If you lower the clip (raising the needle) you will only richen the mixture...no way to damage anything...I wouldnt think raising the clip could lean it out enough to hurt anything either...
I would change the oil before even starting the engine... The oil from China cant be that good...
How much oil do I put in?
Old Feb 25, 2010 | 11:24 AM
  #40
OneTenCC's Avatar
The Taotao 110's hold just under 3/4 of a quart. The ID plate on the front will spec 15w40 motor oil. I had some Napa Fleet 15w40 on hand so that's what I put in mine on it's first oil change.
Joel
