high idle?
Old Apr 21, 2010 | 09:20 PM
alex288288's Avatar
Red face high idle?
hey all.
got a quick question for everyone, i have a 200cc Daymak and its been relativity decent for the most part.
now my question is:
when i start up my engine, it has a really high idle, really loud.
i went to adjust my idle screw which, doesnt seem to be doing much.
Next problem:
i just did an oil change, and now all of a sudden i have oil coming out of my carb and down my overflow tube, i know this isnt good at all. any reason for this? and how do i fix this! b\c it might be related to my high idle as it looks like the oil is going into my Carb.
thanks in advance!
Old Apr 22, 2010 | 07:07 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Usually a high idle is caused by a vacuum leak some where between the carb and the engine.. I find them by carefully spraying carb cleaner where the carb meets the maniflod and the mainfold meets the engine.. Any change, either it dies or runs better is a sign of a vacuum leak...
Any chance you overfilled the crankcase with oil?
Old Apr 23, 2010 | 08:19 PM
alex288288's Avatar
hey all. i have another question, i noticed a screw on my carb, (inside my air filter)
is that my air screw?
picture is here :
Old Apr 26, 2010 | 08:24 AM
KTM Patrol
Former Chinese POW!
picture is here :
If there isnt another screw coming out the side or bottom of the carb...That could be it.. does it move/adjust? how many turns out was it set at?
Old Apr 26, 2010 | 12:59 PM
Sawyer's Avatar
Regarding high idle. Make sure your throttle cable is adjusted properly. So that when its at idle the slide plunger in the carb is acutally resting on the idle screw. Not lifted off a bit which of course can cause the idle to be high.
Old Apr 26, 2010 | 11:23 PM
alex288288's Avatar
update:
i noticed after about 10mins of riding, it will idle even faster. (2,00RPM or higher) its loud lol. it will idle low when i first startup (900RPM) but as i said it will get really loud after bout 10mins, any updates or help would be great thanks!
Old Apr 27, 2010 | 03:56 AM
nimadd's Avatar
Another cause of high idle would be partly clogged pilot jet causing a lean burn. When was the last time the carb was cleaned?
Old Apr 27, 2010 | 02:10 PM
alex288288's Avatar
Red face
i couldnt tell you when its been cleaned last lol, im not even sure how to for that matter. but i kinda figure it could be the carb making all the noise.
Divergent12
Aug 19, 2023 05:26 AM
Cummins Driver
Sep 11, 2019 01:22 PM
donintennessee
Aug 19, 2015 02:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
MNatv89
Jul 7, 2015 11:36 AM
