little help
Old Jun 30, 2010 | 07:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Did you ever adjust or check the valves? Have you ever adjusted the fuel screw?
A high idle would cause the jumping forward problem you have.... Unless your idle is normal and does it...Then id think clutch adjustment or maybe the clutch is frozen up.
Old Jun 30, 2010 | 03:36 PM
jonny.n's Avatar
hi, i havent adjusted the valves yet, and yes i have been playing about with the fuel screw, (turned the wrong one thinking it was the throttle screw), i wouldnt say it has a high idle, its revs a bit once started, then calms down if you know what i mean, i dont know how to adjust the clutch, cheers
Old Jun 30, 2010 | 04:14 PM
KTM Patrol
Former Chinese POW!
OK.. the valves wont affect the clutch... mainly will make it hard to start/idle..
So if its in gear its moving? always? Can you hold it back(not let it move) with the brakes without the engine dieing?
Old Jun 30, 2010 | 04:31 PM
jonny.n's Avatar
i kind of know what your asking yes you sometimes hold it back with the back brake, but only when in 1st gear and its heat up, the last time i thought i had it set perfect (wouldnt move as much when put into gear) once i put it into gear it would just die out,
Old Jul 2, 2010 | 05:05 PM
  #15
KTM Patrol
Former Chinese POW!
Try adjusting the clutch... right side of the engine (when sitting on quad) small cover in the side of the case... usually held on by 2 screws... remove the cover.. underneath is a nut and a bolt with a screw driver slot cut in the end of it... with the engine off... loosen the nut a turn or 2.. tighten the screw/bolt with a screw driver until it stops.. turn it out 1/4 turn and tighten the nut..
Old Jul 2, 2010 | 05:38 PM
  #16
jonny.n's Avatar
willl give that a try mate, need to get a new exhaust first will keep you updated, thanks
