Remote
Old Jul 20, 2010 | 06:40 PM
Edward L Cassidy's Avatar
Default Remote
Can I remove the remote control system and not interfear with starting or ignition
Old Jul 20, 2010 | 07:07 PM
Jaster94's Avatar
check this out in case you haven't read it yet.
http://forums.atvconnection.com/chin...h-removal.html
Old Jul 20, 2010 | 10:25 PM
Just read that thanks I have some of the same problems the key switch does not do anything starts and runs with the switch off. The start button on the handle bar does not work And the lights switches don't work in the same assy.I need help trying to get this right for my grandson's birthday on the 31st
Old Jul 20, 2010 | 11:59 PM
LynnEdwards's Avatar
Electrical Expert
Jaster94's post is awesome as usual. Sometimes the search engine on this site isn't easy to use, and it helps me tremendously when search savvy guys help with links to similar posts.
Here is another current post:
http://forums.atvconnection.com/chin...rter-quit.html
Disconnect your remote and try the two methods in the above link. Report back your findings. What I'm trying to determine is whether the light switch problems are related or different.
What brand quad? Engine size? Year?
Old Jul 26, 2010 | 07:40 PM
Sorry it took me so long to get back the only info I got is MODEL 110 cc
it is made by Yongkankg Wangli Hardware it is a 2006 or 2007 with a loncin 6wngx motor. Replaced key switch because key was broke off the only thing that does not work is the lights it starts with the remote and button on the handle bar works and the key turns it off so the lights is my only problem PLEASE HELP
Old Jul 26, 2010 | 10:09 PM
Electrical Expert
Since you can start it with the handlebar start button, and shut it off with the ignition switch, that proves that both halves of the two section ignition switch are working.
That leaves the light switch itself, the headlight bulbs themselves, and the wiring (including ground returns). I would get a voltmeter and probe the pins going to the lightswitch. One pin should have 12 volts DC whenever the ignition switch is turned on, and another pin should have power when the ignition switch is on *and* the light switch is on. If you get this far then check for power at the headlight, and makes sure the ground return of the headlight is really tied to ground.
I'll be traveling the rest of the week. I probably won't get back on line until Sunday at the earliest...
Old Jul 26, 2010 | 10:56 PM
Thanks I will look at all that
Old Jul 27, 2010 | 04:52 PM
I am only getting voltage on one pin at the plug going to that light switch assy. That pin is for the starter button in that assy
Old Aug 30, 2010 | 05:52 PM
Have a new problem quad runs for about 30 min then no spark. Black & yellow wire at the coil is dead. Getting a pulse signal from stator & voltage reg. is it cdi box
Old Aug 30, 2010 | 06:47 PM
Forum might have help read some other posts just for giggles I went out to quad still would not start unpluged remote starter quad fired right up and is still running
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
toonces
Sep 5, 2015 01:14 PM
AlotL1keVegas
Aug 18, 2015 09:38 PM
Hatrackr
Aug 11, 2015 09:03 PM
sublime250
Jul 11, 2015 11:52 AM
