GY6 engine codes...answered
Old Jun 26, 2013 | 03:27 AM
  #21
Mc7donald's Avatar
reminds me when i was learning how to read vins hahaha so long ago!
Old Jul 8, 2013 | 06:13 AM
  #22
chrisb710's Avatar
Default GY6 Engine code has lost me!
Hi recently got my hands on a quad bike as part of a deal when repairing a V8 engine, so far I know very little about it other than its a Chinese made 2003 quad (checked the VIN Number ), It has a GY6 type engine but the engine code is:
M125GD
0300758
any ideas please?
Old Sep 13, 2013 | 06:36 PM
  #23
leeelkington's Avatar
Default help please
can any one help me decode this please been trying to finde out my make for weeks thanks Name:  DSCF2202_zpsa9254302.jpg
Old Apr 26, 2014 | 12:24 AM
  #24
gyminis's Avatar
Thanx :-) as this is just what i needed,ur the best!!!!! jim
Old Apr 26, 2014 | 12:29 AM
  #25
gyminis's Avatar
Default yr made?
I really do appreciate all your help as i got nowhere at all the other sites? any way is there any way of telling what year this motor was made? jim
Originally Posted by Mr.Firemouth
You can find your engine code below the CVT cover, beside the oil drain plug.
We'll take a look at the most common engine code: 157QMJ.
The first thing to note is that the actual code always starts with the first number, and continues for a total of 6 digits. Anything extra is a manufacturer-specific information that won't be covered here at this time.
Lets disect the code starting with the first digit:
(Digit #1) Corrasponds to the number of cylinders. All GY6 engines are single cylinder, so this number will always be 1.
(Digit #2 and #3) This is the bore size in metric millimeters, in the case of the 157QMJ, our bore is 57mm. Note that 57.4mm bore engines fall under the "57" designation.
(Digit #4) relates to the style of engine. All GY6 engines are designated "Q".
(Digit #5 and #6) The actual size of the engine. The second letter ascends consecutively for each 10cc. MB = 50cc, MC = 60cc, MD for a 70, MH = 110cc, MI = 125cc, MJ = 150cc
That is pretty much it for the standard codes stamped on most GY6 and other Chinese engines. We will add more information about manufacturer-specific codes as we find it out.
Old Feb 27, 2017 | 06:47 PM
  #26
jwpetersen84's Avatar
Default 150cc, 139qmb scooter engine
So I can't seem to find out anything about my scooter motor. I do know for a fact that it is not a 50cc. It looks almost exactly the same as the 157qmj but on the case it says it is a 139qmb. What does this mean? And how do I order parts for it?i was guessing that the cylinder stud is different and that that may be the true meaning of the numbers.
Old Feb 28, 2017 | 04:43 PM
  #27
Default It's not a 150cc, I'm guessing it's a 100cc or 110cc.
I took the motor apart today and it's not what I expected it to be. The piston is either 51 or 52mm so I'm guessing it's a 100cc or 110cc motor. Obviously this disproves the 139qmb meaning a 39mm bore and all that. And yes, it's all stock and original parts. The case and all the parts with it or exactly the same as a 152qmi or 157qmj motor but the cylinder size is smaller and it's marked as a 139qmb.
Old Feb 28, 2017 | 04:56 PM
  #28
This is from Wkikipedia. Don't know if it helps you or not.
Specifications of GY6 variants[3][4]
Engine Displacement Power Bore × stroke Compression ratio
139QMB 49.5 cc (3.02 cu in) 2.95 hp (2.20 kW) at 7,500 rpm 39 mm × 41.4 mm (1.54 in × 1.63 in) 10.5:1
152QMI 124.65 cc (7.607 cu in) 6.8 hp (5.1 kW) at 7,000 rpm 52.4 mm × 57.8 mm (2.06 in × 2.28 in) 9.2:1
157QMJ 149.6 cc (9.13 cu in) 8.6 hp (6.4 kW) at 7,000 rpm 57.4 mm × 57.8 mm (2.26 in × 2.28 in) 8.8:1
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
