New SunL 135 110cc quad
Old Aug 22, 2010 | 11:02 PM
Dynamo55b's Avatar
Default .
Old Aug 26, 2010 | 02:28 PM
Mr.Firemouth's Avatar
I would also track down fuel first from the tank to the fuel bowl. Then I would open the fuel bowl vent screw and see if fuel comes out. If it does the fuel bowl is full and the float is working.
Then I would check the choke and see if any different position helps it run. If it starts and dies right afterwards it is usually not getting gas. Make sure the fuel tank valve is open.
Old Aug 26, 2010 | 04:38 PM
Dynamo55b's Avatar
Default Stuck float
IOT save a bunch of time, find a nylon drift or a 12 inch length of 1/2in OD PVC pipe and give the carb a series of light taps on each side with a rubber mallet. Its worked for me before. It crude, I know, but it works IMO. Note: this does not clean a dirty carb.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
musselmark
Jul 17, 2015 02:40 PM
