Help Identify My ATV
Old Aug 30, 2010 | 09:26 AM
TheWastedYears's Avatar
Default Help Identify My ATV
Hi All,
I found a deal on CL that I just couldn't pass up: A running 97cc quad for $140. The frame was cracked in several places, but that's nothing a welder couldn't fix.
So now that I have it.... what is it? Can anyone help me identify make/model?
Old Aug 30, 2010 | 09:31 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Do you have the vin#?
If so, try this and it may give you a little more info.
Old Aug 30, 2010 | 09:44 AM
Sweet! I think the VIN survived the welding, so I'll check it out!
Thanks!
Old Aug 30, 2010 | 09:49 AM
Supersock
Hired Gun!
First thing that came to mind when you said cracked frame was Sun-L.
Old Aug 30, 2010 | 10:53 AM
SunL makes a "Hummer" model that's 110cc that looks a lot like this one, but w/ a beefier front bumper/rack. Maybe that's the updated version?
Old Aug 30, 2010 | 11:46 AM
TLC's Avatar
TLC
Looks like my friends 110cc "GIO".
Old Sep 8, 2010 | 07:12 PM
ATV-For-Life's Avatar
does look like a gio but its blue haha how was the frame craked?
Old Sep 8, 2010 | 08:45 PM
Supersock
Hired Gun!
First guess without knowing, I'd say by the swingarm. But it sounds like it was cracked in a couple of places.
Old Sep 8, 2010 | 09:00 PM
I'm fairly certain it's a SunL "Mini Hummer" that's missing the rear rack and plastic piece on the front bumper. All the Mini's I've seen have been 110cc, though. This one has 97cc stamped on the engine and no front brake. That's the only thing confusing me.
It definitely has the same plastics as the Gio, which is a rebadged SunL.
The frame was cracked at the top (under the seat) and at the bottom (rear engine mount crossmember.) No idea how it happened, but whoever welded it did more harm than good. I had a buddy sleeve the frame, reweld it and fabricate a stronger engine mount. It's solid now!
Now, if I could just stop it from overheating. It'll handle about an hour's worth of slow trail riding in 90 degree weather before it stalls out and calls it quits. Once it cools off, it'll start back up again.
I'm thinking of installing a couple of 120mm computer fans to get some more airflow to the engine.
toonces
Sep 5, 2015 01:14 PM
Thwapp
Aug 25, 2015 09:54 AM
gdmclnh
Jun 13, 2015 05:32 PM
dubya1
KTM
Aug 4, 2002 11:42 PM
