DINLI Helix 90
Old Sep 19, 2010 | 08:07 AM
DJDSNOW's Avatar
Default DINLI Helix 90
What should the compression be on this machine? very low power at start. Could it be the transmission?
Old Sep 19, 2010 | 08:25 AM
Jaster94's Avatar
Default need more info
low power? when starting machine? OR, after it's running, it has poor take off power under a load? is a kid riding it or an adult?
Old Sep 19, 2010 | 09:49 AM
LT80's Avatar
LT80 Expert
Approx 100 pounds compression.
It could be a problem in the clutchs. Better maintenence them.
Old Sep 19, 2010 | 09:53 AM
DJDSNOW's Avatar
Default Reply
It starts fine, However it feels like it is in a higher gear. When in Neutral it revs and sounds fine. When I put it in gear it hesitates like not enough power. If I push it to get it going in starts running fine. Could it be in the gears? I took off the clutch casing and it looks in working order. I also replaced the cylinder and piston. The compression reads 90 PSI, is this ok?
Old Sep 19, 2010 | 10:03 AM
DJDSNOW's Avatar
How do I service these clutchs?
Old Sep 19, 2010 | 10:05 AM
DJDSNOW's Avatar
It starts fine, However it feels like it is in a higher gear. When in Neutral it revs and sounds fine. When I put it in gear it hesitates like not enough power. If I push it to get it going in starts running fine. Could it be in the gears? I took off the clutch casing and it looks in working order. I also replaced the cylinder and piston. The compression reads 90 PSI, is this ok? My son is riding this machine 70 lbs
Old Sep 19, 2010 | 10:42 AM
LT80's Avatar
LT80 Expert
90 should be fine.
This machine should pull a adult w/no problems.
Clutchs: you remove the clutch cover, remove the nuts holding the clutchs. check the rollers for flat spots and replace. Check the bearings in the rear clutch.
Altho, is there exhaust comming out the pipe? The pipe (spark arrestor) can get plugged and act just like this. Pull the arrester out and clean the lil screens. Try running it w/o the arrestor to see how it goes.
Old Sep 19, 2010 | 11:14 AM
DJDSNOW's Avatar
Thanks for the advice, I will try the exhast 1st, then go to the clutch's. Will let you know my results.
Old Sep 19, 2010 | 12:47 PM
DJDSNOW's Avatar
The exhast is not servicable. It is a sealed unit. I will try the clutch's next.
Ashley S
Feb 18, 2024 08:56 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
mojave300ex
Jan 17, 2003 09:37 AM
Pryormountainman
Nov 22, 2001 02:15 PM
Pryormountainman
Nov 21, 2001 01:19 AM
