valve adjustment ??
Old Nov 7, 2010 | 08:04 AM
lotus7's Avatar
Default valve adjustment ??
I`m sorting out a second hand chinese 110cc horizontal air cooled atv and had a go at setting the valve clearances but I am not sure I did it right.
I had the spark plug out to see the piston top and the 2 inspection covers off the side of the engine to turn and view the markings.
I did have the piston at TDC by looking at it through the spark plug hole AND noticing a different mark through the inspection hole-then I did the valve clearances.Does it matter which way I turned the crankshaft?clockwise or counterclockwise?
But how do I know that this position is Top Dead center for the compression stroke? I may have set it up 180 degrees out.Is there not another TDC on a 4 stroke? Help! I dont want to start puting this atv all back together only to have to redo this later.
Hope someone can help.
Old Nov 7, 2010 | 03:05 PM
ATV-For-Life's Avatar
watch this vid shows u 100% how to do it helped me when i rebuilt my motor!
YouTube - "How To" Adjust the valves on a 125cc Kikker Hardknock by California Hardknock Tech Center
Old Nov 7, 2010 | 05:59 PM
lotus7's Avatar
Default great info
Thanks ATV 4 life ! Really appreciate it.I`m going to redo it as per video.I never thought to check you-tube for help
Old Nov 8, 2010 | 11:18 AM
hey no problem i try to help people as much as possible!
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
