wiring#@!!!*%(&#$@
Old Jan 23, 2011 | 02:51 PM
gzeek's Avatar
Default wiring#@!!!*%(&#$@
I recently aquired 2 of these quads(Taotao ata 110 d)I've got a wiring mess.I think some tweekers got ahold of it,but the neighborhood kids,my wife,and myself are dying to take it for a ride.Does annyone have a english wiring diagram? HELP
Old Jan 23, 2011 | 10:43 PM
LynnEdwards's Avatar
Electrical Expert
I've not seen a TaoTao 110cc wiring diagram. But the wiring on chinese quads is often similar enough between brands that you can get away without a specific diagram fro TaoTao by looking at other brand wiring diagrams.
But to narrow down which diagram to start with, does your CDI have 4 pins or 5 pins? See below:
Old Jan 31, 2011 | 09:45 AM
seamorewatervip's Avatar
do not dispare mine was in the same condition when i got it it just takes some time, some research, and a lot of tracing wires. but you will eventually get it figured out...I would start with determining if you have power in and out of the remote kill controller and key switch, and check the fuse on the little wire form the positive side of the battery. then check all of the safty switches. open or no continuity means run closed has contunity means it is killing. dont spend money on parts untill you have figured out witch on is the at fauilt.. other wise you will have a new electrical system.
