Rear wheels already wobbly after two weeks
Old Feb 26, 2011 | 10:53 AM
Jaster94's Avatar
Originally Posted by EastPointFL
I bought it brand new
That wobble you see on the axel is actually a metal sheath that goes over the axel that can get off center. I removed the sheaths on both sides and noted that the axel is perfectly straight.
well, worth a try i reckon. hope coolster makes good on it for ya. good luck. have fun.
Old Aug 23, 2014 | 07:00 AM
Jakeo625's Avatar
Originally Posted by LynnEdwards
Or is it the axle spline / hub free play? If you raise up the quad rear wheels, grab the wheel, and try to rock it side to side, does the wheel hub wiggle on the axle?
Sorry to bring up an old thread but I just acquired a 110 quad not sure on brand for my kid anyways the back wheels wobble and it's the wheel hub rocking on the axle how do I fix this?
Old Aug 23, 2014 | 08:14 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Usually you need to put a washer or 2 under the axle nuts... the nuts have run out of thread on the axle and arent tightening the wheel hub.. just getting tight as there arent enough threads.
This play can also be taken up on the inside of the wheel hub.. washers in between the axle spacer and wheel hub will do the same thing..
greg74
Sep 10, 2019 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
Jul 15, 2015 02:07 AM
rcappie4
Jul 10, 2015 04:54 PM
Jul 7, 2015 11:00 PM
