Monsoon 90cc atv
Old Mar 15, 2011 | 12:12 PM
  #41
jacob_royer's Avatar
It has a heavy pushbutton wired in for the starter (bad relay? ) I'm not sure that any of the quads original wiring is good. The on/off switch is going to be add backwards for killing the ignition. The start button isn't hooked to anything. Neither is the key switch. So if I could make it ground the kill switch with key off that would be fine since its not doing anything as it is. Not so sure how I'd wire that... as I'd want it to be grounded with key off .
Old Mar 15, 2011 | 06:14 PM
  #42
Ok i cleaned the carb re-installed it and got it to idle ok. BUT it has isues reving up! If i spray carb cleaner on the intake boot i can get it to rev up instead of bog. It has some cracks in it. So im assuming this is my issue. Where can i find one? it looks to be the same as a yamaha jog 90cc but not 100% sure.
Old Mar 15, 2011 | 06:25 PM
  #43
Just found this! Parts manual with exploded views and part #s for the 50/90cc yerfdog/monsoon
http://www.bmikarts.com/PDF/23000.pdf
Old Mar 17, 2011 | 02:11 PM
  #44
Ordered an intake. Hopefully that fixes my issues.
Old Mar 18, 2011 | 03:59 PM
  #45
Replaced the intake and made things better also replace fuel filter and plug but it bogs bad when you give it gas! I have noticed that if I back out the screw on bottom of float bowl it just drips gas ? Is. This a sign of float problems? I found new carb for 36 shipped on ebay is it worth a try or do I have other issues ?
Old Mar 18, 2011 | 11:07 PM
  #46
LynnEdwards's Avatar
Electrical Expert
I don't know, but I'm wonderng if the screw on the bottom of the float bowl is a drain screw?
Old Mar 19, 2011 | 12:44 AM
  #47
I'm pretty sure it is a drain. But seems it should Di more than drip if I'm getting enough gas. Everything else around here has a healthy stream of gas if you backout the drain screw.
Old Mar 19, 2011 | 08:01 AM
  #48
How do you check/set the timming? im wondering if its off since it seems ok wide open but bogs so bad when you give it gas it wont rev up unless you have the rear wheels jacked up off ground.
Old Mar 20, 2011 | 09:37 PM
  #49
Electrical Expert
For those coming here down the road via search engines, this thread has been restarted here with a different subject line:
http://forums.atvconnection.com/chin...bogs-down.html
Follow it for more info.
Old Mar 31, 2011 | 01:02 PM
  #50
Default *****Generic 5 pun cdi will not rev****!!
DISREGARD MY WIRING INSTRUCTIONS FOR THE 5 PIN CDI! IT WILL NOT REV UP BECAUSE OF THE TIMING CURVE!
You MUST Use a 2 stroke cdi!! EBay search "jog cdi" the performance cdi box for $20 works great! You CAN however use the generic China coils they do work with a 2 stroke engine!
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
AlotL1keVegas
Aug 18, 2015 09:38 PM
