How can you tell if quad is charging
Old Mar 6, 2011 | 07:07 PM
ocurly's Avatar
Default How can you tell if quad is charging
I charged battery starts up fine took the cable off while its running it stays on.after about a few hours driving turning off and on battery is dead ,could it be bad battery or is it not charging its a tao 110 we just bought it a few days ago any info would be helpful thanks
Old Mar 6, 2011 | 08:53 PM
LynnEdwards's Avatar
Electrical Expert
Start up the quad and run the engine at a medium fast speed with the headlights off.
Use a meter to measure the DC voltage right on the battery terminals. It should read 13.5 to 14.5 volts DC. If it does then your charging system is working. If it does not then it needs more troubleshooting. What voltage do you measure?
slowgsxr97
Mar 18, 2022 03:40 AM
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
