zmc 200 u smokes
Old Mar 30, 2011 | 02:36 PM
eastsider's Avatar
Default zmc 200 u smokes
i have a zmc 200 u . has less than 100 kms. started smokeing. tore down engine. couldnt find anything wrong. put it back together. now the oil just bails through the pipe. smokes like a train. my question is. what is the engine realy. and what should i look for.
Old Mar 30, 2011 | 03:12 PM
snow racer's Avatar
Exaust valve is probly open way to much.
Old Mar 30, 2011 | 03:20 PM
eastsider's Avatar
push rod engine. . as i said less than 100 kms.
Old Mar 30, 2011 | 03:21 PM
eastsider's Avatar
i want to no were is the oil comeing from.
Old Mar 30, 2011 | 03:42 PM
snow racer's Avatar
is a push rod 2 stroke or 4 if its 2 im lost im a 2 strole idioet
Old Apr 2, 2011 | 12:36 PM
outofline's Avatar
I would guess that it is your valve seals probably the exhaust seal!
Old Apr 3, 2011 | 01:09 AM
BIG MEAT NUGGET's Avatar
That is the same problem I had on my Roketa 250. I tried two things at once trying to eliminate the problem
1. I removed the cylinder head, flipped it over and realized that the exhaust seal was bad with just a little hole in the corner.
2. I replaced the rings on the piston thinking maybe it could be bad as well.
I bolted it all back together and it runs like a dream now.
Best of luck to you friend!
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
