110cc Loncin engin problem
Old Sep 11, 2011 | 04:48 PM
NH JIM's Avatar
Default 110cc Loncin engin problem
I have a Loncin 110 cc, under the engine there are two bolts. First bolt is the oil drain plug. The second has a oil baffle and spring. I removed the bolt and the baffle shot out. When I was ready to re-install the baffle I discovered the spring on the ground. I inserted the spring and installed the baffle and bolt. I removed the bolt to check on the spring tennision on the baffle and it was zero. Tried to remove the spring but it's stuck inside. Question: What is the baffle for,and is there a problem with starting the engine?
Old Sep 13, 2011 | 11:28 PM
LynnEdwards's Avatar
Electrical Expert
I never worked on a 110cc machine, but you are not alone in pulling out the wrong bolt.
The bolt and spring is the cam chain tensioner. If you search the forums for "110cc cam chain tensioner" you'll find lots of company.
I think the spring goes between the baffle and bolt. So you'y need to get that spring out and assemble it correctly before reinstalling it. But remember I've no experience on this quad.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Dame0927
Oct 29, 2015 10:13 PM
alix
Jun 28, 2015 03:28 AM
FWhitt
Jun 13, 2015 02:22 PM
kevbowe
Jun 1, 2015 01:17 AM
