Help please with I guess chinese atv
Old Oct 23, 2011 | 05:32 PM
chad h's Avatar
Default Help please with I guess chinese atv
I just became an owner of a chinese atv i think? No name on it except for Tao Tao on the engine cover. I am having problems getting it started, spark, no spark, then no spark again. Tried different things I've read on these forums but dont know If I'm doing things right. I am new to this whole fourwheeler life style. Any help will be welcomed, I am a diesel mechanic so good with tools and hands just need some guidence.
Thanks,
Chad h.
Old Oct 23, 2011 | 08:32 PM
LynnEdwards's Avatar
Electrical Expert
First step is to see if your CDI is DC powered or AC powered.
How many pins are on your CDI? Five or four?
I'm assuming this is the 110cc quad?
If not, then it's possible you may have a 6 pin CDI (2 pin and 4 pin connector)...
Old Oct 26, 2011 | 07:14 PM
chad h's Avatar
Default HELP please
The cdi has 5 pins. I disconnected the blk/wht wire and started getting fire ,it was a good spark then lost it and cant get it back. I understand that this wire is related to the safety system. I also have done a comp. test on it and it didnt look good only about 40psi. Ive seen the quad run before i ended up with it and it really hauled butt, so i really didnt think that the engine had comp. problems. Like I said when it comes to this small stuff I'm really clueless. Thanks again for your help
Old Oct 27, 2011 | 12:06 AM
Electrical Expert
The kill switch wire is not really part of a safety system unless you list the ability to turn the quad off a safety device. You turn the running quad engine off by killing the spark. If the spark is killed you can also prevent a quad from starting up.
The normal safety interlock schemes keep you from turning the starter motor unless the brakes are applied (or you're in neutral, or you're clutch is pulled in, or any combination of these). It's the same idea as the system that keeps you from starting up your car in drive...
40 PSI is not good. You need to fix that first.
fredrikrosen
Oct 29, 2016 07:56 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
01ssls1
Sep 22, 2015 06:50 AM
CosmoM
Sep 21, 2015 04:57 PM
johnny1982
Sep 13, 2015 07:41 PM
