How to add brake fluid ?
Old Oct 27, 2011 | 11:28 PM
pvillefball421's Avatar
Default How to add brake fluid ?
I have a hensim 150cc gy6 and the brake fluid reservoir tank is empty i tried to put dot3 fluid into reservoir tank but it wouldn't get sucked in though brake line do I need to open bleeder valve?
Old Oct 28, 2011 | 07:35 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You either need to bleed the brake (like a car) or buy a brake system vacuum.. (Harbor Freight sells one) and pull the brake fluid through the system.
Old Oct 28, 2011 | 11:44 PM
95wolv's Avatar
First you need to find out why it was empty of fluid in the first place, if it is leaking, adding wont help much.
Joe454
Nov 20, 2020 01:19 PM
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
