Falcon 110 - new owner
Old Nov 7, 2011 | 06:24 AM
Blue03Cobra's Avatar
Originally Posted by LynnEdwards
Do you have an automatic choke (also called a bystarter valve) on this machine? Or in other words, do you have electrical wires going to the carburetor?
No, manual choke only that seems to work as designed. Part of my carb cleaning was to also clean the throttle plate and "neck" of the intake side of the carb.
Having said that, the rubber fittings that connect the airbox to the short tube air intake and the intake to the actual carb are cracking and I may not have a good seal. The quad will probably not see mud, so does anyone have a recommendation on an airbox replacement or open filter setup?
Old Nov 15, 2011 | 05:56 PM
Thumbs up
Thanks to all, with a new solenoid and thorough cleaning of the start switch assembly, the quad fires and starts without being "hotwired". Runs, idles, accelerates and rides great.
Next up, painting and refinishing.
Old Nov 17, 2011 | 04:45 PM
Jaster94's Avatar
post before and after pics! we'd like to see your progress!
Old Nov 20, 2011 | 04:17 PM
Wink
Here you go:
Before
During
After
It was dusk before I got done, so I couldn't get great pics, but the difference is still pretty striking
Old Nov 20, 2011 | 04:28 PM
  #15
Jaster94's Avatar
Fantastic! i like the mustang too! i'm a Ford guy! quad looks great! thanks.
Old Dec 18, 2011 | 02:54 PM
  #16
football55's Avatar
I have the exact Kazuma you have posted pics of can you tell me what size bolts are used to mount engine to frame they keep vibrating out when my son rides
Old Dec 19, 2011 | 06:18 AM
  #17
Jaster94's Avatar
i don't know what size metric bolts you need, maybe Blue03Cobra does, but if the bolt goes in to a welded nut on the frame, use a longer bolt with blue loctite. the longer bolt, if you're interested, could use another nut on the end so as to double nut the stud. just an idea. but don't use the red loctite, just the blue if they're vibrating out. if it doesn't have a welded nut to the frame, consider using teflon locknuts and lock washers. just an idea.....
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
