Weak spark, how to test, and identify quad
Old Nov 25, 2011 | 11:51 AM
mattnj's Avatar
Default Weak spark, how to test, and identify quad
I have aquired a quad bike, no idea what make/model it is, I was told its a Kazuma, but cant confirm. The engine number is 1pe52qmg which accoring to a website i found makes it a 100cc two stroke. Its in good condition and looks like a decent bit of kit, but it doesnt run....
.....compressions seems ok, and the carb/fueling I am happy with after a stip down and clean out, It have never fired ever, not even once, i even tried it with some easy start, so I am looking at the ignition.
It does spark if turned over quickly (using an electric drill) without a spark plug in, but if you drop the speed down of the drill then the sparking becomes intermittant and at slow speed (turned over quickly by hand) there is very irratic sparks and they "look" very weak and thin.
So, what is the most likely cause? stator? magnets in the flywheel gone weak? or coil pack and how can I test each bit?
Thanks in advance for any help provided.
Old Nov 25, 2011 | 06:29 PM
Jaster94's Avatar
start with a new spark plug properly gapped. let's eliminate a double grounding on the old one when it's inserted. try turning it over with the new plug outside and check for spark. then insert it and crank it!
Old Nov 26, 2011 | 12:53 AM
mattnj's Avatar
thanks, i have tried a new plug, same thing
Old Nov 26, 2011 | 09:35 PM
LynnEdwards's Avatar
Electrical Expert
Since this is a mystery quad, what sort of ignition system do you have? Is it CDI based, or something else? Is this quad electric start, or pull rope/kickstart only? When you say that the spark becomes intermittent or non existant at lower spin speeds, how would you say that threshold speed compares to normal cranking speed, or pull rope/kickstart speeds (as the case may be)? Have you checked for spark while using standard methods of turning the engine (crank/pull rope/kick start)? Do you get consistent spark then?
Old Nov 27, 2011 | 02:59 AM
mattnj's Avatar
its fixed!
I had to make a tool to pull the flywheel off, then took the stator off (behind the flywheel) and it was all corroded where it attached to the engine casting, cleaned that up with a file, put it back on, fired up instantly!
Thanks
Old Nov 27, 2011 | 09:18 PM
Electrical Expert
I'm glad you got it running
Bigredjeep
Apr 10, 2020 02:55 AM
Frisky2050
Apr 9, 2020 11:19 AM
tweeder
Jul 5, 2015 01:57 PM
jag6510
Jun 15, 2015 05:59 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
