leipai 50 cc bogs after 10 minutes of riding
Old Nov 27, 2011 | 11:24 AM
the_legend_1981's Avatar
Default leipai 50 cc bogs after 10 minutes of riding
My kids quad bogs out and stalls after 10 minutes. I think its flooding. Could it be the air/fuel mixture or something else?
Old Nov 27, 2011 | 11:39 PM
LynnEdwards's Avatar
Electrical Expert
So after 10 minutes it stalls.....
How long before it starts back up? Does it start right away? Do you have to wait 5 seconds? 10 minutes? An hour?
Why do you think it's flooding? Do you have a fuel shutoff (petcock) valve? After it stalls what happens if you try to restart after you turn off this valve [crank with wide open throttle (WOT) for a bit]?
What is the history of this quad? Did you buy it new? Has it always done this? 2 stroke or 4 stroke? Do you links to anyone who sells these quads?
You have to provide more info if you want help...
Old Nov 28, 2011 | 07:56 PM
its a 4 stroke. looks like a kazuma engine and has all the same parts as my brothers 110(not sure of make at this moment. I was able to start it right away but i'd have to hold it wide open to get it cleared up. I'm gonna try and clean the carb in detail and see what happens after that because since it has not been able to idle. the guy i got it from said the float used to stick but that seems to be fine.
Old Nov 28, 2011 | 07:58 PM
when i start it it revs high on its own and then dies out unless i keep it running. I have the idle screw turned in quite a bit to make it try and idle which may be why. it can drive it around the yard fine you just have to keep it running at low speeds, which is not easily done by my kids since they are just starting. this quad model is a 2006 hornet. does that make sense?
Old Nov 29, 2011 | 12:53 AM
Electrical Expert
That sounds like the float is stuck open. Do you have a fuel filter installed? Do you have a fuel shutoff valve? If you shut off the fuel does the quad run correctly for a few minutes (after you start it with wide open throttle and consume the excess fuel sitting in the float bowl)?
Do you see fuel coming out the overflow hose?
Old Nov 29, 2011 | 05:19 AM
yes there is a fuel filter. i dont have a shutoff valve. I dont see any fuel coming out of the overflow. what can i do about a stuck float?
Old Nov 29, 2011 | 03:06 PM
So i cleaned the jets today and it idles and runs good. Should i add stuff to the gas occasionally to keep it clean or will riding it weekly keep it fresh? Also should i put a fuel shutoff valve on it?
Frisky2050
Apr 9, 2020 11:19 AM
cbcole02
Sep 7, 2015 06:16 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
tmoose
Jun 30, 2015 08:28 AM
