a Few problems solved and a few to tackle
Old Dec 20, 2011 | 08:51 PM
ezhoops's Avatar
What does the air/fuel screw look like? I adjusted the throttle screw is that the same thing and if not how do I get to the air/fuel screw
Old Dec 21, 2011 | 09:44 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
On a 4 stroke its a fuel screw.. on a 2 stroke its a air screw.. most are on the bottom of the carb..in sort of a pocket in the back of the bowl..it will have a spring under it.. If you see a screw and think that cant be it.. its impossible to get to.. you have found it..
Old Dec 21, 2011 | 12:09 PM
Jaster94's Avatar
that's correct. you have then found the proverbial piece of the puzzle in which an apparatus was built around it!. i know everyone has seen something like it in their lifetime. something so hard to get to, it seems the factory started right there and built the quad/car/pickup truck/or whatever around it!. i never understood that, BUT, it happens!
Old Dec 21, 2011 | 09:29 PM
ezhoops's Avatar
Well, I did both. Cleaned carb and adjusted screw, ran much better but I will let it cold start before I'm happy
Old Jun 27, 2012 | 02:19 PM
  #15
ezhoops's Avatar
Still having the same problem, stalling when i give it gas. Should i adjust the air screw inside the carb? I think i should adjust the air jet next to the main jet? What do you think? I've tried adjusting the small impossible to find screw with no luck.
Old Jun 27, 2012 | 08:19 PM
  #16
Jaster94's Avatar
did you remove the jets out of the carb when you cleaned the carb? were they in your hand? could you see daylight through all of the orifices?
how to clean a carb on a ATV - YouTube
Old Jun 27, 2012 | 10:14 PM
  #17
ezhoops's Avatar
Yes, i removed them and could see dylight thru them. Ran small wire thu them.
Do i need to adjust them or tighten them down? I didnt overtighten just snug
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Schneider
Jul 24, 2015 05:05 PM
hondarider1234
Jul 21, 2015 11:53 PM
